Selection bar
I am training on an Avid system with someone else’s pre-existing settings, so it may be an option that you can turn on or off, but the blue selection bar has one solid line, and another one to the right of that which is a dotted/dashed line. What’s the purpose for having two selecion lines? It seems to be a difference of a few frames or so, and is kind of annoying when i am using the CNTRL key to quickly snap to clips. It also makes using the EXTEND tool somewhat annoying because it doesn’t accurately snap to the clip (or in the case of the extend tool, it won’t extend at all due to the empty frames). Does this make sense? Any advice?
