Activity Forums Adobe After Effects selecting the difference between frames
  • selecting the difference between frames
    Posted by Mak Tzoep on February 4, 2010 at 5:25 pm
    hello hippies
    am I dreaming or have I actually seen/read about a video program (plug?) that is able to select the difference between frames and turn it into a mask?
    Im not an AFX avid user (no pun), just use the program for editing and simple effects. But I could use this now: say I film a street with static objects. Then a person passes through the frame. I tell the prog/plug to select the difference, thus being able to turn the result into a mask.
    Any ideas?
    thanks!
    Michael Szalapski replied 16 years, 7 months ago 4 Members · 4 Replies
  • Todd Kopriva
    February 4, 2010 at 5:54 pm
    You’re describing the Difference Matte effect.
    “About keying: color keys, luminance keys, and difference keys”:
    “Difference keying works differently from color keying. Difference keying defines transparency with respect to a particular baseline background image. Instead of keying out a single-color screen, you can key out an arbitrary background. To use difference keying, you must have at least one frame that contains only the background; other frames are compared to this frame, and the background pixels are made transparent, leaving the foreground objects. Noise, grain, and other subtle variations can make difference keying very difficult to use in practice.”
    Note the warning in that last sentence about how difficult his can be to pull off in practice.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Todd Kopriva
    February 4, 2010 at 6:31 pm
    The Difference Matte can get you started. But, for example, if you have noise or grain, then you’ll have artifacts in your matte that you’ll need to clean up with any of several techniques. I once got a decent matte using the Difference Matte effect after I applied the Median effect to the matte—removing speckles from the matte.
    So, don’t give up without trying—but also know that you will likely have some more work to do. And you can’t even hope to get a good result without starting with a locked-down shot and good, clean footage with minimal (preferably zero) compression artifacts.
  • Walter Soyka
    February 4, 2010 at 6:40 pm
    [Mak Tzoep] “say I film a street with static objects. Then a person passes through the frame. I tell the prog/plug to select the difference, thus being able to turn the result into a mask”
    If your goal is to remove the person from the shot, you might look into Boris FX Motion Key.
    Walter Soyka
  • Michael Szalapski
    February 4, 2010 at 6:56 pm
    You know what works even if your footage is noisy? Rotoscoping!
    Yay!
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
