Activity Forums Maxon Cinema 4D selecting several points and set each position
  • selecting several points and set each position
    Posted by Ronny Traufeller on May 12, 2015 at 9:35 pm
    hi
    when i select multiple points on a mesh, i get an axis in the center
    and so i can move them all together.
    i want to put in new values for the x position,
    but it changes the postion of the group, not
    of each point, what can i do?
    thanks in advance
    Brian Jones replied 11 years, 3 months ago 2 Members · 4 Replies
  • Ronny Traufeller
    May 13, 2015 at 8:38 pm
    i just saw somebody else doing it like this:
    select multiple points, scale the whole group to 0 in X,
    so they line up and have the same x position.
    Now just type in the new one for all of them
    traufeller.de
  • Brian Jones
    May 14, 2015 at 2:33 am
    ah, that’s what you meant. Thanks for following up with the solution.
  • Ronny Traufeller
    May 14, 2015 at 2:42 pm
    hey
    the reason i needed this is because
    i am using a symetry object for modeling
    and so there is no gap or overlaping on the
    vertexes representing the mirror axis.
    cheers
  • Brian Jones
    May 14, 2015 at 3:24 pm
    another way to do that is to select the points you want to ‘flatten’ and set their Size to zero in the Coordinates Manager
