Activity › Forums › Avid Media Composer › Selecting render drive
  • Selecting render drive
    Posted by Shane Ross on November 21, 2008 at 10:58 pm
    Every time I go to render something or make a speed effect, Avid defaults to my system drive…seeing as it is the one that has the most room. But I keep telling it “No doofus, I want the RENDER drive. See, the one named RENDER? Render there.” And it does….but it doesn’t remember this.
    It’s been a while since I was on an Avid…is there a way to tell Avid, use that drive ALL THE TIME dummy?
    Thank you.
    Shane
    Ra-ey Saleh replied 17 years, 10 months ago 5 Members · 5 Replies
  • Shane Ross
    November 21, 2008 at 11:06 pm
    Leave it to the assistant editor to know. THEY KNOW EVERYTHING! Or should. In this case, she did.
    OK…Avid 3.0.5, FYI…in the MEDIA CREATION preference, you can tell Avid to filter out the system drive, and then in the RENDER tab of that preference you can set where the default render/effect creation drive is.
    Thank goodness for assistants.
    Shane
  • Job Ter burg
    November 22, 2008 at 12:39 pm
    Now keep monitoring where your Avid writes your renders. In my experience, it does not always behave they way you set in the Media Creation settings.
  • Craig Hirshberg
    November 23, 2008 at 4:42 am
    Assistant editors are the BEST!
    You try to teach them everything you know, then they turn the tables and show you something you never knew or would have thought about.
    Gotta love them young kids!
    Here’s a shout out to ASSISTANT EDITORS!
    Craig
  • Terence Curren
    November 23, 2008 at 5:47 am
    Number of issues here.
    1: Avid will render where you tell it to in the “media creation” settting… unless you run out of space on that drive.
    2: When it asks if you want to render to “effect source” drive (or something like that), it means the drive the original media is on that you are rendering from.
    3: When it asks for a drive and you look at the available drive options in the window, the one in BOLD is not the drive that is selected, however it is the drive with the MOST space available at the time.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Ra-ey Saleh
    November 24, 2008 at 4:04 am
    ‘2: When it asks if you want to render to “effect source” drive (or something like that), it means the drive the original media is on that you are rendering from.’
    Really? I did not know that, I always assumed it was just the drive with the most space on at the start of a session.
    Thanks, learn something knew…
