Activity Forums VEGAS Pro Selecting multiple titles from the menu to run as a set
  • Selecting multiple titles from the menu to run as a set
    Posted by Ron Ressler on January 8, 2013 at 9:49 pm
    Hello,
    I am creating a promo video with multiple subjects. I would like the menu to present a list of subject-titles (in either chapter or playlist form) and allow the user to select multiple subjects to watch back-to-back and run in a loop. I know about the “end action” function but I do not know if a menu can offer multiple title selections and then play only those titles.
    For example: My menu would have 10 titles listed. Of those 10, the user likes 5. He would select (or check-off) those 5 that he likes and then those 5 would play as a seamless set (the order of which does not matter) in a loop. Is this possible?
    Thank you,
    Ron
    Ron Ressler replied 13 years, 8 months ago 3 Members · 4 Replies
  • Graham Bernard
    January 8, 2013 at 10:44 pm
    Eh? I understand but what I was having in mind would have been massively unwieldy, but here goes.
    If I want to make a selection from 3 separate items:
    A – – B – – C
    This would give the following for “A”
    Selection 1 = A
    Selection 2 = A+B
    Selection 3 = A+B+C
    Then I would need to go to “B”
    Selection 4 = B
    Selection 5 = B+C
    Then I would need to go to “C”
    Selection 6 = C
    So this would give me a nominal series of:
    1x2x3 = 6 OR 3!
    So I could envisage a set of “nested” Menus each allowing the Viewer to select their “selection”.
    Now, for your selections for the 10 Items that would be “10!
    Is this correct?:
    10x9x8x7x6x5x4x3x2x1 . . . . .
    Anyways it’s massive.
    The reason for this obscure Maths is that needing to make a “flat” Selection, which I believe is the ONLY way DVDA is set to do the alternatives you’d be wanting, would require this.
    Any other takers on this? I’m truly interested.
    Cheers
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
  • John Rofrano
    January 9, 2013 at 2:32 pm
    As Graham pointed out in painful detail, you are asking for something that a DVD cannot do and therefore you would have to provide a button for every possible combination which is 10 * 10 or 100 buttons.
    The short answer is:
    What you want to do is not possible with a DVD.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    January 9, 2013 at 5:18 pm
    What I have used in the past, was OPUS Pro.
    OP would produce any number of configurations media<>menus<>selections in many different ways. However, that would be published on a DVD-ROM and would NOT be available to be played on a DVD STB which needs to have a “platter” that adheres to the DVD Convention.
    DVDs are great, but when it comes to this type of “wish” are severely limited AND limiting in their feature-set.
    (Now, if only one could sensibly connive, conspire and construct to make the 100 selections . .? STOP, let it go . . . . !)
    Grazie
  • Ron Ressler
    January 9, 2013 at 5:26 pm
    Thank you for your input Graham. I appreciate your time and thoughts on the matter. I was just trying to avoid customizing and create one unified DVD.
    Take care,
    Ron
