Activity Forums Adobe After Effects Selecting multiple mask points when a layer is turned off?
  • Selecting multiple mask points when a layer is turned off?
    Posted by Peter O’connell on October 17, 2005 at 12:54 am
    Hi, when I roto I use a solid with its visibilty turned off, that way I can load all my frames into RAM and work much more quickly. The only problem is that some of the functionality associated with masks doesn’t work when the layer is off. For example I can’t grab many points at once, as I can if the layer is turned on. Does anyone have a solution for this?
    pete
    John Dickinson replied 20 years, 10 months ago 2 Members · 3 Replies
  • John Dickinson
    October 17, 2005 at 6:28 am
    How about leaving the solid layer turned on but making either the its Opacity or Mask Opacity 0%?
    JD
  • Peter O’connell
    October 17, 2005 at 1:12 pm
    Hi John, when you do that you lose your ram preview as soon as you change a vertex on any mask even if the opacity is 0. Unless I’m missing something.
    Pete
  • John Dickinson
    October 17, 2005 at 8:19 pm
    That’s correct. I don’t know if you have any other choice though.
    JD
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
