Activity Forums Apple Final Cut Pro Legacy Selecting multiple clips on the Timeline
  • Selecting multiple clips on the Timeline
    Posted by Kwesi Johnson on November 8, 2006 at 6:26 pm
    I have a bunch of clips with transitions, one next to the other, that all need to be increased to 7 seconds long. I have heard there is a quick and easy way of doing this, but I’ve looked and looked to no avail.
    Thanks for your time,
    Kwesi
    Bret Williams replied 19 years, 10 months ago 3 Members · 3 Replies
  • Kevin Monahan
    November 8, 2006 at 6:48 pm
    Lengthening all of the clips at once? No, there isn’t a way. Or do you mean lengthening the transitions?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Kwesi Johnson
    November 8, 2006 at 7:16 pm
    I mean both the transitions and the clips. No go?
  • Bret Williams
    November 8, 2006 at 10:18 pm
    Transitions yes. Clips no.
    Transitions – Set the default transition to whatever you need. The select the range of clips and drag them to the canvas window and select overwrite with transition. It’ll edit them into the timeline where the playhead is and where you’re patched. It’s obvious after you try it.
