Activity › Forums › Adobe After Effects › Selecting key frames
  • Selecting key frames
    Posted by Gon Perdigao on June 14, 2016 at 8:49 am
    Hello, I have 900 layers with position keyframes, just in and out.
    I want to select the first keyframe of each layer, is there a shortcut or a script I might use?
    Because is taking me 20m to select the keyframes when after effects don’t crash on me.
    Cheers
    Gon Perdigao replied 10 years, 3 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    June 14, 2016 at 1:24 pm
    If you select all the layers and press “p” you will see only the position keyframes for all layers. Then you can drag around a bunch of keyframes to select them, and shift-drag to add to the selection. Just be careful not to start the dragging on a layer, but in the space holding the keyframes.
  • Gon Perdigao
    June 14, 2016 at 1:26 pm
    Thank you for you reply!
    That works when you just have a “few” layers, now when you have 900, is not so easy to select them.
    What I did in the end was just selecting a bunch at the time holding the shift key.
    But it must be an easy way (expression or shortcut) to select these amount of key frames.
    Cheers
