Activity › Forums › Apple Final Cut Pro Legacy › selecting destination in compressor
  • selecting destination in compressor
    Posted by Nick Ryan on January 31, 2006 at 5:51 pm
    Greetings all,
    Another question I should know the answer to. When I’m batching stuff through compressor (v. 2), and I don’t want the new files in the same directory as the old, I have to select “destination”, “other”, and then tell it where I want it to go. Is there a way to select a destination for *all* of your batched files, instead of having to manually select the same destination for each file? I tried selecting “destination” from the drop down menu, hoping that was a global change but no such fortune. If anyone would like to throw the probably-highly-obvious answer my way I’d appreciate it.
    Nick
    Nick Ryan replied 20 years, 8 months ago 3 Members · 3 Replies
  • Jeff Carpenter
    January 31, 2006 at 5:52 pm
    As would I.
    I’m afraid we may be out of luck, however. I’ve never met anyone who could answer this question for me, either.
  • Carey Harrison
    January 31, 2006 at 7:07 pm
    Hi Nick.
    Not sure if this is what you are asking but…apple-a (select all) of your batch then choose your destination. It will apply to all that you selected. Hope that helps.
  • Nick Ryan
    February 1, 2006 at 3:41 pm
    Lo! It worketh! Yes! You have just saved me much tedious clicking and grumbling in the future.
    Just to clarify for any others’ sake: “select all” in the compressor batch window (command-A), then select destination from the drop down menu (don’t try selecting destination in the batch window). Also works for choosing an encode.
    Now if you’ll excuse me I have to get busy walking around and saying “Why didn’t I think of that?”
    The answers. They’re often so simple.
    Nick
