Activity Forums Adobe After Effects Selecting Bezier Control Point is Awful in AE
  • Selecting Bezier Control Point is Awful in AE
    Posted by Brandon Little on March 13, 2018 at 5:26 pm
    Ugh…I know this issue has been a problem for a while, but it’s driving me bonkers!
    Since there is no “direct select” tool like hitting A in Illustrator, After Effects can’t sort out what I’m trying to click on with a shape layer. I’m attempting to animate a bunch of bezier lines on shape layers, which you can do, but it’s obnoxious. Most of them are finished now, but they’ve been a nightmare – just moving a couple of points.
    I can sometimes click and drag a control point, and other times it categorically refuses to let me click where I want. It selects it as an object and tries to move the entire thing, but actually clicking the control point I want is well nigh impossible at times. There has GOT to be a better way than all this guesswork and clicking around. Drilling down into CONTENTS > SHAPE > PATH sometimes helps, but come on!
    /rant
    help?
    William Kemmler replied 4 years, 7 months ago 4 Members · 5 Replies
  • Brandon Little
    March 13, 2018 at 5:52 pm
    FWIW, and to help you people from the FUTURE (future…future…future…echo….)
    It’s a lot harder to do this if your pen control points line up on the corners of a bounding box. Trying to work around this can be…challenging. It’s a little easier if your endpoints don’t line up with any of the corners.
  • Walter Soyka
    March 14, 2018 at 2:15 pm
    Does it help if you manually switch to the Pen tool (G) instead of the Selection tool (V)?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Brandon Little
    March 14, 2018 at 2:28 pm
    Yes, that actually DOES seem to help. Slight risk of accidentally adding new bezier points, so it looks like switching back and forth with the Move tool helps.
    Good tip, thanks.
  • Richard Garabedain
    March 14, 2018 at 11:32 pm
    i was going to suggest the same…but i agree with the topic…animating the camera is a pain at times
  • William Kemmler
    February 25, 2022 at 7:44 pm
    old/dead thread but the key is to click and drag and select the point you want with a rectangular selection box
