Activity Forums Adobe After Effects Expressions Select specific character expression
  • Kalleheikki Kannisto
    May 15, 2018 at 4:36 pm
    The longer your text, the slower it will be, as every letter is evaluated for every frame.
    If the text doesn’t need to change from frame to frame, you can precomp and freeze frame. You can still manipulate the layer in various ways.
    Senior Graphic Designer
  • Yaniv Cahoua
    May 17, 2018 at 7:01 am
    Hi thanks,
    If I precomp I lose the ability to animate the text with the text animator….
    Is there a way to bake only the expression selector ?
    http://www.yanivcahoua.com
