Activity › Forums › Adobe Audition › select range
select range
Posted by David Gruwier on December 27, 2011 at 12:49 pmI can’t for the life of me figure out how to select a range on the timeline, and have audition only playback and loop that selection (or alternatively, only play and loop the current view).
I’ve been going through the reference manual and 20+ google searches, but I just can’t figure it out.
Is it even possible? And if so, how?//David
____
https://clearcutgames.net/Howard Rappaport replied 7 years, 2 months ago 7 Members · 6 Replies -
Steven Talley
December 31, 2011 at 5:56 pmHave you looked at Markers points and ranges. From these you can create playlists or loop the range by selecting the Loop button in the play/record controls or hit Ctrl-L. Hit M to add a marker. Right click to change a marker point to a range. Drag to change the range.
In the Help file in Audition search for Working with Markers. CS-5.5 -
Greg Digenti
April 16, 2013 at 5:22 pmI realize this thread is a few years old, but it was one of the first and only links to come up in a Google search when I was trying to figure out how to do this. So maybe this will help someone else out, since no one in the other threads I found seemed to know the answer either.
If you go into Preferences>General and check the “Return to Start Position on Stop” and put your playhead at the beginning of your selection, it will play just your selection.
Sherridon Routley
July 11, 2013 at 7:49 pmI was confused as well … Just use the TIME SELECTION TOOL available in the toolbar.
Jordan Robinson
February 22, 2014 at 6:03 amThere’s no time tool in my toolbar! I seem to have searched everywhere. Is there something i’m missing?
I’d really like to select a portion of a clip in Soundbooth so i can use the de-noiser.
Thanks -
Shahed Naderi
June 25, 2017 at 4:22 pmfor selection you just need to drag over wave form , it snaps to markers , then you can remove , crop, export from range etc
Howard Rappaport
July 2, 2019 at 5:57 pmNew subscriber reviving this old thread as I had the same question. Super-easy solution that all of you probably know, but new Audition users like me might not:
-Select portion of waveform in multitrack window using Time Selection Tool (T)
-Click on Loop Playback button (or ⌘L) next to Record button in transport bar at bottom
-Hit play
-Dunzo!
