Activity Forums Adobe After Effects Expressions Select random layer as a Value
  • Select random layer as a Value
    Posted by James Barry on June 20, 2015 at 8:40 am
    I’ve created randomly seeding dots that move, and I would like to connect the dots with lines. I’ve created the dots and I know to use BEAM to connect the dots using the dots positions as begin and end points for the BEAM.
    What I would like to do is to put in an expression for the beginning and end points for the BEAM an expression that randomly selects which dot is connected to the next dot.
    So like something like
    thisComp.layer("Dot (random number between 1-60)").transform.position
    With “Dot” being the layer names for the dots (eg: Dot 1, Dot 2, Dot 3, Dot 4, etc)
    Is this possible?
    Thank you in advance.
    James Barry replied 11 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 20, 2015 at 2:24 pm
    I haven’t test it, but this should work:
    thisComp.layer(“Dot ” + (Math.floor(random(60))+1)).transform.position
    Dan
  • James Barry
    June 20, 2015 at 4:25 pm
    Perfect, thanks.
