Activity › Forums › Adobe Premiere Pro › Select multiple transitions in Premiere Pro
Stephan Heiniger replied 5 years ago 5 Members · 13 Replies
Oliver Peters
September 11, 2021 at 9:04 pmWait, actually I think you can. Select the first transition. They Shift+select the others. Make sure that the transitions are highlighted/selected, not the cut points. Then right-click and “Set Transition Duration” and enter the value. You do have to Shift+select one each one to get a group, but after that it’s a global change to the selected transitions. The one caveat is that if you applied a bunch of default 4-frame crossfades it will get a bit touchy to carefully select the transition without accidentally selecting anything else.
Stephan Heiniger
September 12, 2021 at 6:10 amYeah… That’s how I do it now… Selecting them one after the other. “Clicking on each single one of them”. That’s what sucks so much especially if I’m working with 12 Audiotracks and I want to change the fade from 4f to 10f for all of them.
Stephan Heiniger
September 12, 2021 at 6:25 amHere’s a feature request at Adobe. Maybe you find the time to vote for it..
Thanks for replying so quickly and creatively!
