Activity Forums VEGAS Pro Select clip without moving timeline marker
  • Select clip without moving timeline marker
    Posted by Eric Vinyard on March 1, 2011 at 5:27 pm
    Normally in Vegas, when you click anywhere on any track in the timeline, it moves the marker to that point. I want Premiere Pro behavior, where clicking on a clip in the timeline only selects it and doesn’t move the timeline marker. I’d rather drag the marker to where I want it, or click above the tracks in the timeline (which is currently possible) in order to move it.
    Otherwise, there isn’t a simple way to select the clip I need when my marker is already in the right place, if I have the wrong clip highlighted.
    Anyone know if this is possible? I’ve exhausted the menu looking for a solution and haven’t found one.
    Eric Vinyard replied 15 years, 7 months ago 2 Members · 2 Replies
  • Mike Kujbida
    March 1, 2011 at 5:45 pm
    Hold down the Ctrl key and then click on the desired event.
  • Eric Vinyard
    March 1, 2011 at 11:28 pm
    Eh, I’ve tried that and it only adds that event to my current selction, which means I also have to deselect any already selected events using the same method. This is a bit cumbersome for the speed at which I work. It also means that if I have other clips selected that I can’t see, they remain selected. It’s just not quick enough for me.
    The closest thing I’ve found so far is just to zoom way in and to click on the event I want where the marker already is, that way it doesn’t move. That still adds in all sorts of extra steps that I don’t need or want.
