Activity › Forums › Apple Final Cut Pro › Select all forward
  • Select all forward
    Posted by James Ewart on September 11, 2014 at 11:45 am
    I still mis this tool. I understand Gaps helps out for pushing things along but what if you want to select everything forward of a certain point but what quick way of selecting everything forward if you want adjust volume for example?
    Yes I can Shift select in the Timeline Index but it’s a bit convoluted. Any thoughts?
    Bob Woodhead replied 12 years ago 4 Members · 6 Replies
  • Noah Kadner
    September 11, 2014 at 12:16 pm
    Lasso or Timeline Index are pretty much all you’ve got to work with.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • James Ewart
    September 11, 2014 at 12:27 pm
    Such a simple little tool but so useful.
  • Bob Woodhead
    September 11, 2014 at 2:26 pm
    Seems like for the times that I use it now, TL Index isn’t too many clicks. I think I used Select Forward far more often in Legacy, where the advantage of using a mag TL wasn’t available. As I recall, I usually used s/f to open up a gap in Legacy, or paste attributes. Much faster using a gap clip or clip searches in the index.
  • James Ewart
    September 11, 2014 at 2:56 pm
    Yeah I agree. But today I miss it.
  • Bret Williams
    September 11, 2014 at 5:49 pm
    Gotta agree with Bob. But you made a good point about audio, however I never used it for that. I don’t even use a gap clip usually, because usually at the point I want to move things forward there’s already a clip in the primary I can drag out. Then use the P tool and drag it back. No better or worse than legacy, just different. But actually, probably less prone to error. If you miss something in legacy or a clip gets deselected, etc. then you may not notice till it’s all screwed up.
    Why is it nobody ever misses “select all backward”? It just gets no love.
  • Bob Woodhead
    September 11, 2014 at 10:23 pm
    Never look back!
