Activity Forums Adobe Premiere Pro Seeing stacked double video clips
  • Seeing stacked double video clips
    Posted by Robb Bomboy on October 24, 2013 at 1:18 am
    Hello,
    I’m seeing two clips stacked in the viewer. They are literally one on top of another and unconstrained. In the timeline, they are on a single layer.
    They appear like this only when paused in Pr. Playback appears normal. When I export the footage to MPEG2 or mov they appear stacked.
    Why?
    Robb Bomboy replied 12 years, 11 months ago 1 Member · 1 Reply
  • Robb Bomboy
    October 26, 2013 at 4:14 pm
    So I found that I was mixing 1920×1080 with other size formats. When I removed the other sizes from the timeline, everything works fine. I have “Scale to fit” checked.
    Can you not mix resolutions in prp even when the sclae to fit box is checked?
