Activity Forums Apple Final Cut Pro Legacy Seeing fields/swapping fields/field dominance issues
  • Seeing fields/swapping fields/field dominance issues
    Posted by Ben Wharton on July 13, 2006 at 7:04 pm
    An Avid editor taking his first steps with FCP would love to know if there’s a way to step through individual fields while looking at a sequence?
    Because – I have rushes with their fields reversed – cutting on 2 field rather than first, and encoding to MPEG2 looks like a mess as a result.
    Following that is there an elegant way to reverse the fields? Or do I need to resort to something like RE:Vision Effects FieldsKit?
    Any help/pointers gratefully received.
    Ben
    Graeme Nattress replied 20 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Arnie Schlissel
    July 13, 2006 at 7:58 pm
    G Field in Nattress set 1. nattress.com
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • Ben Wharton
    July 13, 2006 at 8:00 pm
    Apologies but I really don’t understand the very short reply!
  • Moody Glasgow
    July 13, 2006 at 8:06 pm
    Let me translate:
    1. Go to nattress.com
    2. Navigatge to Products -> Set 1
    3. Navigate to G Field
    does that help? 😉
    moody glasgow
    smoke artist / editor
  • Arnie Schlissel
    Sorry. go to nattress.com & look at his G Fields filter in Set 1. It allows you to swap fields.
    Arnie
  • Ben Wharton
    July 13, 2006 at 8:10 pm
    Yes, that helps. Thanks.
    Meanwhile, I’d still like to know if I can view individual fields in FCP. Do you know if there’s a function key or keyboard combination to hold down while stepping through one frame at a time?
  • Ben Wharton
    July 13, 2006 at 8:48 pm
    Anyone else know if viewing fields in FCP is possible?
  • Kevin Monahan
    July 13, 2006 at 8:59 pm
    No, you can’t. Unlike Avid, it’s not possible w/o a plug in.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Ben Wharton
    July 13, 2006 at 9:20 pm
    Kevin –
    Thanks for the bad news. But I’ll look into the Natress plugin. And of course AE…
    Yawn.
  • Graeme Nattress
    July 13, 2006 at 11:35 pm
    Field swapping can now be done in FCP – there’s an inbuilt plugin for it. To view fields in sequence, G Map Frames in the standards conversion package does it very well.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
