Activity Forums Boris FX Seeing FCP timeline video in RED plug-ins
  • Seeing FCP timeline video in RED plug-ins
    Posted by Kieran Matthew on November 29, 2007 at 7:00 pm
    Hi Folks,
    I’m running RED 4 in FCP 5 on a MacPro set-up. When I try to use RED as a generator or a filter I can’t seem to get it to display the underlying video from the host.
    What am I doing wrong?
    K
    Kieran Matthew replied 18 years, 9 months ago 2 Members · 4 Replies
  • Dave Dipinto
    November 29, 2007 at 7:41 pm
    Hi Kieran,
    As a filter you should only see the video from the clip your applied to and as a generator you won’t see any host video by default.
    To see host video other than the clip you’re applied to you must add it into one of the video wells in the Filters window.
    I hope this helps.
    Dave
  • Kieran Matthew
    December 5, 2007 at 9:25 pm
    Hi Dave,
    Apologies for my tardy reply.
    Thanks for the info. Problem is I just seem to get green when I do the Boris as a filter thing.
    Any ideas?
    K
  • Dave Dipinto
    December 5, 2007 at 10:02 pm
    Hi Kieran,
    There’s the missing piece! If you’re seeing green it’s because you have your FCP timeline set to Unlimited RT. Change that to Safe RT and everything should work as expected.
    Dave
  • Kieran Matthew
    December 5, 2007 at 10:17 pm
    Hi Dave,
    Ahh! Thanks muchly!
    K
