Activity › Forums › Avid Media Composer › Section of my sequence freezes/”Serious Error has occurred” prompt
  • Section of my sequence freezes/”Serious Error has occurred” prompt
    Posted by David Powell on January 6, 2012 at 1:33 am
    Like the subject says. When I start up the project, I get the “serious error” prompt. Most of the sequence is fine but a section of it is frozen. I’ve tried relinking the sequence as well as rebuilding the database. I don’t know what else to do or whats causing this.
    David Steiner replied 14 years, 5 months ago 3 Members · 2 Replies
  • Scott Cumbo
    January 6, 2012 at 1:46 pm
    usually it’s corrupt media. make a copy of your sequence, then narrow down the problem area by pulling sections out until you figure out where your problem is. than just get that media again (weather it’s a recapture or re-import)
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • David Steiner
    May 1, 2012 at 2:45 pm
    I had this bug when I re-rendered quicktime files from After Effects, with slightly different timings.
    To solve the problem, I deleted the old clips, deleted their references in the timelines, and re-edited them. Not very handy, but it worked in my case…
    good luck
    D.
