Activity Forums Adobe After Effects secret prefs in MAC version of AE?
  • secret prefs in MAC version of AE?
    Posted by Scott G on November 1, 2005 at 11:57 am
    hi,
    i’ve got the secret prefs in the windows version by holding down shift when cycling through preferences categories, but does the mac have the same thing? holding down shift seems to do nothing. are there no hidden preferences in the mac version for clearing ram every x frames rendered?
    thanks,
    scott.
    Frank Van mourik replied 20 years, 11 months ago 5 Members · 5 Replies
  • Tim Vaughan
    November 1, 2005 at 12:07 pm
    Hold down the shift key, go to AE–>Preferences–>General–>cycle thru the panes and you will see the “secret” pref. So in answer to your question: Yes, AE’s version for the Mac does have the secret pref.
  • Frank Van mourik
    November 1, 2005 at 12:14 pm
    oke never heard of this secret? what does this function do?
  • Vinnie
    November 1, 2005 at 2:08 pm
    Does emptying the cache every so many frames speed up a render?? If so what are the negatives of this option…everything has a negative….
    thanks
    Vinnie
  • Steve Roberts
    November 1, 2005 at 2:27 pm
    No, it slows down a render, apparently. Do a test to find out how much for your particular project.
    But … it can make impossible renders possible by avoiding crashes. If your RAM fills up before your render is done, you crash. Therefore, purging is good.
    Steve
  • Frank Van mourik
    November 2, 2005 at 11:05 am
    This ‘secret’ is great! and works just perfect for complex comps to render ‘without’ crashing! thanx a lot you guys!
    bye Frank
