Activity Forums Adobe After Effects Secret Prefs in AE 7?
  • Secret Prefs in AE 7?
    Posted by Uwe Lansing on January 25, 2006 at 7:33 pm
    with 6.5 sometimes I had a lot of problems with bigger projects => AE crashes a lot until I saw this posting
    “To find the Secret Prefs, hold down shift when accessing AE’s prefs — keep the shift key down until you see the prefs dialog box. Try setting it to purge every 5 frames during Make Movie.”
    Now, in AE 7 the same thing, but it seems there is no possibility to set “purge every 5 frames during Make Movie”. AE 7 crashes after a while during Render to an avi. Is there any solution now like the old one?
    regards
    Uwe
    Chris Zwar replied 20 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • Barend Onneweer
    January 25, 2006 at 8:03 pm
    I can’t check right now, but I’m pretty sure that the secret preferences are still there. You keep shift down, go to the preferences, and in the preferences you have a dropdown menu for different prefs. In this dropdown you should find one that’s named ‘secret’.
    I’ve also had a project that would be so incredibly RAM hungry that it would crash during rendering. I noticed that rendering with Caps-Lock active (which disables preview) it didn’t crash at all. You could give that a try…
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Mylenium
    You could try and hack the prefs file manually. look for this section:
    “Pref_PURGE_EVERY_N_FRAMES” = 0000
    Mylenium
    [Pour Myl
  • Andrew Kramer
    January 25, 2006 at 8:10 pm
    It’s still there. Just checked.
  • Uwe Lansing
    January 25, 2006 at 8:12 pm
    Oh yes, thank you Barend. I forgot holding down shift. The possibility with Caps-Lock active I
  • Stone Reader
    January 25, 2006 at 11:32 pm
    Why does AE have secret prefs at all? They seem pretty useful — and it seems pretty stupid to hide them.
  • Andrew Kramer
    January 26, 2006 at 1:52 am
    some users shouldn’t where the self destruct button is.
  • Chris Zwar
    January 26, 2006 at 11:29 pm
    This question was asked on the Media-Motion After Effects email list and was answered by an Adobe employee. I don’t think they’d mind me pasting the response here:
    “Hold down Shift when bringing up the prefs via the menu command, and an
    extra “Secret” panel is available.
    The “purge every N frames” option should slow down your renders, as all
    caches are blown, but sometimes it is actually helpful. The reason it isn’t
    an official feature is that we consider it a bug if using that option is
    helping you. Please let us know via the bug report web form on Adobe.com:
    https://www.adobe.com/misc/bugreport.html
    We may need your specific project to reproduce the problem, so please
    provide real contact info.
    DaveS”
    So there you go.
    -Chris Zwar
    Motion Graphics Designer
    Will animate for food
