Activity Forums Adobe Premiere Pro Secondary Color Correction Doesn’t Work
  • Secondary Color Correction Doesn’t Work
    Posted by Geoffrey Shea on April 2, 2012 at 4:56 pm
    Hi. I’m using Premiere Pro CS5 on a new Macbook Pro with a Thunderbolt Display. Everything is working great except Secondary Color Correction. Using RGB Color Corrector (or 3-Way) I set the Output to Mask. The screen goes white. I select the Secondary Color Control eyedropper but the image stays white! I.e. I can’t see the image to make a selection. And if I select blindly, the whole mask turns black. I’ve tried it without the Thunderbolt display, but its the same. Is this a software glitch or am I overlooking something? Thanks.
    Ann Bens replied 14 years, 5 months ago 3 Members · 5 Replies
  • Jeff Pulera
    April 2, 2012 at 7:15 pm
    I believe you would select MASK only AFTER selecting the key color, to check the results as a black/white key image.
    Jeff Pulera
    Safe Harbor Computers
  • Ann Bens
    April 2, 2012 at 7:34 pm
    I think that was fixed in 5.5.2.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Geoffrey Shea
    April 2, 2012 at 9:21 pm
    Well, kinda. It is apparently fixed in 5.5.2. But I’m at 5.0, so I can’t get there from here. 🙂 According to the last paragraph on this page at Adobe. Thanks for heads up. I guess it’s time to upgrade…
  • Geoffrey Shea
    April 3, 2012 at 1:49 pm
    I upgraded to 5.0.4 and the problem persists. The Adobe post (above) says its related to monitor settings but I get it even with a single monitor. Seems like a known bug. Oh well.
  • Ann Bens
    April 3, 2012 at 3:49 pm
    Try moving the sliders in the hue, see if that will help.
