Second Monitor
I have just got a UGA-165 which I want to use to set up a second monitor. It is all connected with Windows and works OK as a second monitor, but I want to set it up with PP CS5 to make sure she runs OK with speed / resolution.
However as much as I’ve tried to read up on / search for video to explain how I set up the second monitor I am unable to do so. If anybody knows how I’d greatly appreciate it. If the UGA adapter doesn’t run smooth I’ll be sending it back today hopefully.
Thank You
