Activity › Forums › Apple Motion › Seasons Template – Leaves Particle Emitter
  • Seasons Template – Leaves Particle Emitter
    Posted by Sam on October 5, 2006 at 3:21 am
    Hi
    I was trying to create leaves flying off the screen and decided to load the Seasons Template to see how it was done. I noticed that the particle emitter just says “leaves”.
    I couldn’t figure out what particle emitter was used to create the leaves fall down the screen.
    If I were to create a Wipe transition where a bunch of leaves fly across the screen from left to right, how could I acheive that effect?
    I am assuming that the “leaves” particle is somewhere on my hard drive as well?
    Thanks for your help
    Sam
    Winston A. cely replied 19 years, 12 months ago 2 Members · 1 Reply
  • Winston A. cely
    October 5, 2006 at 6:07 pm
    Try this out: https://www.motionsmarts.com/tutorials.html
    It’s probably a combination of the faking collision, and particles tutorials that will get you on your way to what you want.
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
