Activity › Forums › Adobe After Effects › Searching layers
  • Searching layers
    Posted by Dominik Wojtarowicz on August 9, 2008 at 5:27 am
    IS there a way to search layers in AE ? For example i want to only show layers that start with “glow” or any parameter that is called “opacity” regardless if it’s the opacity of the layer or opacity controls of any effects applied to it (if it has one).
    I have one shape layer with 80 shapes in it, i want to set a keyframe for the fill opacity of all 80 shapes. This does not work the same as selecting 80 layers and pushing T and then setting a keyframe. Any solution to this problem ? I think a search and then the ability to set a key at all the visible values would be handy.
    Dominik Wojtarowicz replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
