Activity Forums Maxon Cinema 4D Searching for nodes : "Distortion" and "Intensity" ?!
  • Searching for nodes : "Distortion" and "Intensity" ?!
    Posted by Keco Mer on February 23, 2024 at 1:11 pm
    Hi, here the two questions :
    1) “Distorter node” : Which node equals the function of the “Posterizer” effect of the standard material ?
    2) “Intensity node” ; Which node can I use to regulate the extent of the effect of any node numerically on another. (think of a kind of “volume control” with a range from 0 to 100 between the output of one node and the input of the other) ?
    Keco Mer replied 2 years, 6 months ago 2 Members · 2 Replies
  • Kouraib Abdmalek
    February 24, 2024 at 10:31 am
    Hi Keco,
    Regarding controlling the intensity of a Node using values between 0 and 100, I think you could do this via Expresso. Below is a link to a tutorial close to what you are looking for. I hope it will be useful to you.
    https://www.youtube.com/watch?v=s9Kl9VNBoCM
  • Keco Mer
    February 24, 2024 at 3:22 pm
    Thank you, I will have a look !
