Activity Forums Adobe After Effects Expressions Searching a way to "rotate" position with a angle controller
  • Searching a way to "rotate" position with a angle controller
    Posted by Clement Dubois on February 1, 2022 at 3:26 pm
    Hi ! 👋
    I am currently working on a animation, and I looking for an expression to link my position to an angle controller.
    By editing the angle controller I want the position to “track the angle”, as You can see on the image, with the black text equal to the angle of the controller :
    I tried some code à found here, but none of them worked :/
    I don’t know if it is possible, but i could save me hours of work !
    Clément.
    Clement Dubois replied 4 years, 7 months ago 2 Members · 4 Replies
  • Filip Vandueren
    February 2, 2022 at 1:56 pm
    The image wasn’t included…
    do you mean something based on trigonometry ?
    Like:
    a=degreesToRadians(45);
    pos = [Math.cos(a),Math.sin(b)]*100;
  • Clement Dubois
    February 3, 2022 at 4:42 am
    Hi Filip,
    Yes the image is missing…
    <div>I think it is the kind of code I am looking for, maybe the image will help you.</div>
  • Filip Vandueren
    February 3, 2022 at 8:10 am
    Yes, this can be done with cos and sin, just subtract 90°, in Maths 0 degrees means the 3 o clock position.
  • Clement Dubois
    February 3, 2022 at 4:35 pm
    Thanks Filip ! After few tweaks I found this code and it worked fine !
    b = thisComp.layer("Null 1").effect("Angle Control")("Angle");
    a=degreesToRadians(b);
    pos = [Math.cos(a) , Math.sin(a)];
