Activity › Forums › Square Box CatDV › search tape name in ‘browse catalogs’ window
  • search tape name in ‘browse catalogs’ window
    Posted by Swami Kevala on March 4, 2010 at 2:22 am
    Hello,
    We are running the standalone version of CatDV. We are backing up SONY XDCAM EX3 HD footage. We backup our data on LTO4 tapes, and create a separate catalog for the data on each LTO4 tape.
    Our files/pathnames are like this:
    Pongal Tourist Festival 2010 at Semmedu 16-Jan-10 – Cam I
    – BPAV
    So – the tape name contains all the event metadata, so I need to be able to search for words in the clip tape name over all our catalogs. (For example I should be able to search for the word “festival”, and get clips back from all the catalogs – using the “Browse Catalogs” window).
    However, it seems that the Browse Catalogs window does not search the clip tape name.
    I understand that this functionality may be available using the workgroup version – but we are not in a position to get that right now. Is there any possibility that this feature could be added to the standalone version?
    Kind Regards
    Swami Kevala
    Bryson Jones replied 16 years, 6 months ago 3 Members · 2 Replies
  • Rolf Howarth
    March 4, 2010 at 9:38 am
    You’re right, it doesn’t seem to search Tape and probably should, so we’ll try to add that in the next update. (Currently it searches clip Name, Bin, Notes and all the user-defined fields).
  • Bryson Jones
    March 8, 2010 at 5:00 pm
    For now, maybe create a new “tape” field, that’s a user field and then Bulk Edit (under the “Tools” menu) the tape name into that new field. That way you could search it.
    bryson
    bryson “at” hidefcowboy.com
    hidefcowboy.com
