Activity Forums Apple Final Cut Pro Legacy SDI to S Video
  • Posted by Cooljay on December 5, 2005 at 12:22 am
    Hello all
    I’ve been checking out the Blackmagic cards, and they look great. However, is there any way to convert their SDI in/out’s to S-Video? I output most of my professional work to SVHS, and having S Video i/o is crucial.
    CoolJay
    Michael Alberts replied 20 years, 9 months ago 4 Members · 3 Replies
  • Graeme Nattress
    December 5, 2005 at 12:40 am
    Just use a DV deck to convert your video to S-video – no magic card needed.
    Graeme
    http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Jeremy Garchow
    December 5, 2005 at 1:19 am
    Maybe you should check into the AJA io (full version). This box will allow you to ingest/output pretty much any form of analog video and also bring in SDI embedded or with separate AES/EBU audio and will also convert your SDI sources to s-video all in the same box.
    If you need an analog only version check out the io LA, or the io LD for an all digital solution.
    http://www.aja.com/io
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Michael Alberts
    December 5, 2005 at 3:58 pm
    The Aurora Pipe Studio also inputs and outputs all types of connections (SDI, Component, Composite, S-Video for video and SDI, AES/EBU, SPDIF, XLR balanced analog and RCA unbalanced analog). All these connections are on the break-out-box. I just got an email this morning stating that it is now on sale for $1299.
    The IO is also a good option, although editing with the IO box drives me batty when trying to edit music or dialogue.
    Michael Alberts
    Ambidextrous Productions, Inc.
