Activity Forums AJA Video Systems SDI to monitor SDI
  • SDI to monitor SDI
    Posted by John Higgins on May 30, 2007 at 2:24 am
    At work I have FCP Studio 2 in a G5 2.66GHz Dual-Core Intel w/ 4GB memory I have the Kona LH card installed and a Sony HDV deck for capture. I connected the Kona to the SDI input on the monitor, but I’m only getting audio out of the monitor. I’ve visited the AJA site and read the pdfs they have, but I need more specifis regarding what connection goes where. The Kona has SDI in and 2 SDI out. I only went SDI 1 out to the monitor SDI in. Am I connecting correctly? Thanks!
    Walter Biscardi replied 19 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • John Ladle
    May 30, 2007 at 3:07 am
    what does control panel say about your current connection?
  • Gary Adcock
    May 30, 2007 at 11:49 am
    [johnpvp] ” I connected the Kona to the SDI input on the monitor, but I’m only getting audio out of the monitor”
    what monitor are you using, since not all support the SDI connections
    my guess is that you do not have an SDI capable monitor.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Walter Biscardi
    May 30, 2007 at 12:30 pm
    [gary adcock]
    my guess is that you do not have an SDI capable monitor.”
    And along with that, also ensure you’re using the latest 4.0 driver from AJA. That is a must for use with FCS 2.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • John Higgins
    May 30, 2007 at 1:12 pm
    The monitor is the Panasonic BT-LH2600W P. I also downloaded the latest 4.0 software from AJA. Thanks for any help.
  • Gary Adcock
    May 30, 2007 at 3:16 pm
    [johnpvp] “The monitor is the Panasonic BT-LH2600W P.”
    SO are you getting bars from the Kona card?
    in the control panel, go to Controls and set it to test pattern > 75% bars
    you should be able to see the bars on the monitor.
    if not you need to call AJA tech support.
    gary adcock
    Studio37
  • John Higgins
    May 30, 2007 at 3:26 pm
    Yes, getting bars…it must be a FCP Studio 2 setting I’m missing…
  • Walter Biscardi
    May 30, 2007 at 3:39 pm
    [johnpvp] “Yes, getting bars…it must be a FCP Studio 2 setting I’m missing…”
    Are you using an AJA Kona Easy Setup?
    If so, ensure that External Video is set to All Frames.
