Activity Forums Blackmagic Design SDI setting in system preferences switches to analog
  • SDI setting in system preferences switches to analog
    Posted by Scnyc on July 31, 2005 at 2:20 pm
    When I set the Black Magic setting in System preferences to SDI input it resets to analog input everytime I close that window. The current work around is to leave it open in the background while I am working. Am I doing something wrong?
    I have just upgraded G5 2.0 DP to Tiger and FCP 5. Also downloaded the latest drivers from Blackmagic as of 7/28/05. I am using a Decklink Extreme card and try to input from Digibeta using the SDI ins and outs.
    Scnyc replied 21 years, 1 month ago 2 Members · 2 Replies
  • Luke Maslen
    August 1, 2005 at 6:34 am
    Hi Sean,
    Are you using an Admin account? An Admin account should never encounter such a problem. I suspect you are using a “Managed” account with “Some Limits” and so your change in the preferences is not being retained. Would this explain your problem?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Scnyc
    August 3, 2005 at 2:38 am
    Yes that fixed it.
    Thank you.
