SDI output bug
Hi there
I installed the Decklink HD Pro in a 10.3.9 MacosX system hoping to see the first results in HD via SDI output … but nothing happened … wether in FCP4.5 nor in Combustion 3 . After installing Tiger the SDI output works fine with Combustion (BMD Driver 4.8), FinalCut 4.5 and After Effects Even though I wondered why there is no desktop output to see on the SDI Monitor out. So I have had no fear to install FCP5 and the new Decklink driver 5.0 respectively 5.1 recommended for FCP5 …. but now the SDI output seems to be defect … wether in Combustion AfterEffects nor FCP any output is possible, only some flicker lines appear. Capturing HDTV was possible and works fine but I would like to see it on a broadcast monitor …. And what about playout back to HD deck if the SDI monitor out doesn
