Activity Forums Apple Final Cut Pro Legacy sdi M&E print to tape using fcp HELP
  • sdi M&E print to tape using fcp HELP
    Posted by Emmet Reddy on December 12, 2007 at 8:55 pm
    Hi all im printing to digibeta using FCP via SDI with a decklink multibridge Ive not used the multi bridge before. Anyway i also need to do an M&E.
    I can probably figure out how to print the master full mix version using assembly or insert.
    What I want to know is do I have to do two passes at it or can i do it in one go could someone please spell it out for me I would really appreciate it Thanks emmet
    Matthew Nelson replied 18 years, 8 months ago 2 Members · 1 Reply
  • Matthew Nelson
    December 12, 2007 at 9:33 pm
    First you need to go into FCP user preferences/Audio Outputs duplicate the Stereo Monitoring setting and change it to a multi channel setting. ie 4 channels for Digibeta. Then create a sequence that just has the number of audio tracks that match your multi channel setting. Then lay in the audio according to tracks you want them to be on tape.
    I only use ETT but this should work for crash records as well.
