sdi M&E print to tape using fcp HELP
Hi all im printing to digibeta using FCP via SDI with a decklink multibridge Ive not used the multi bridge before. Anyway i also need to do an M&E.
I can probably figure out how to print the master full mix version using assembly or insert.
What I want to know is do I have to do two passes at it or can i do it in one go could someone please spell it out for me I would really appreciate it Thanks emmet
