Activity Forums Blackmagic Design sdi M&E print to tape using fcp HELP
  • sdi M&E print to tape using fcp HELP
    Posted by Emmet Reddy on December 12, 2007 at 8:50 pm
    Hi all im printing to digibeta using FCP via SDI with a decklink multibridge Ive not used the multi bridge before. Anyway i also need to do an M&E.
    I can probably figure out how to print the master full mix version using assembly or insert.
    What I want to know is do I have to do two passes at it or can i do it in one go could someone please spell it out for me I would really appreciate it Thanks emmet
    Emmet Reddy replied 18 years, 8 months ago 2 Members · 6 Replies
  • Matthew Nelson
    December 12, 2007 at 9:03 pm
    First you need to go into FCP user preferences/Audio Outputs duplicate the Stereo Monitoring setting and change it to a multi channel setting. ie 4 channels for Digibeta. Then create a sequence that just has the number of audio tracks that match your multi channel setting. Then lay in the audio according to tracks you want them to be on tape.
    I only use ETT but this should work for crash records as well.
  • Emmet Reddy
    December 15, 2007 at 7:13 pm
    Thanks Matthew
    that worked for me, but what i did was nest my full mix into two tracks and then nest my m&e into 2 more and i copied them into the multi channel setting sequence and they played to tape seperately in one go?
    Anyway now i have to this with the next program
    1st channel:
  • Matthew Nelson
    December 16, 2007 at 4:57 am
    With the audio layout you described I would set the audio output Ch 1 & 2 dual mono 0dB. My question is this international left and right a stereo mix that you want interleaved on tape? If so set Ch 3&4 stereo 0dB. If these are to remain non interleaved left and right set Ch 3&4 to dual mono 0dB.
    I set all my audio to 0dB. The mixes I get are all normalized to either -20 or -12. I generally don’t want anything adding to or taking away from their levels.
  • Emmet Reddy
    December 16, 2007 at 3:23 pm
    Thanks for the quick response most of that is pretty clear to me, but what does interleaved non interleaved on tape mean?
    Emmet
  • Matthew Nelson
    December 18, 2007 at 5:54 am
    Interleave is when a stereo mix is saved as single digital file. The L and R samples are written together or interleaved. Reading you post again it sounds like the L and R are separate files. In that case I would use the dual mono 0 dB. I hope this has helped you.
    Matt
  • Emmet Reddy
    December 19, 2007 at 2:12 pm
    Thanks Matthew very helpful info.
    All the best Emmet
