Activity Forums Blackmagic Design SDI Input and Output Solution
  • SDI Input and Output Solution
    Posted by Daniel Skrobowski on February 23, 2015 at 4:25 pm
    Hello,
    I’ll be configuring a workstation that will have to accept an HD-SDI input feed into Telestream Wirecast that will be used for (1) local video recording to a hard drive, (2) web-streaming to YouTube, (3) and HD-SDI output to a DVD recorder (through SDI/composite RCA conversion). I need some advice.
    All of the above functions (1, 2, and 3) can (unless I’m mistaken) be accomplished in (one instance of) Wirecast. Wirecast will also be used to de-interlace the feed (it will be a 1080 59.94i feed, to be de-interlaced to 1080 29.97p) and to apply overlays such as lower thirds to the video feed.
    My Questions:
    Can I accomplish all of the above functions (with the de-interlacing and other processing considered) using one Blackmagic Design Decklink SDI 4K? I know that the Decklink SDI 4K has both an input and output port on it.
    If not, what configuration would you suggest?
    All advice is greatly appreciated.
    Thanks.
    Daniel Skrobowski replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
