SDI Cables, are Neutrik any good
Hi, looking for a 15m HD SDI Cable to connect PC to 2k cinema projector. Found a ‘Neutrik – HIGH PERFORMANCE FLEXIBLE Premium HD SDI HD-SDI BNC Video Cable 15m’ specs are:
Specification
Electrical Characteristics
Max.Conductor(A) DC Resistance at 20°C (Ω/100M) < 2.2
Max.Outer Conductor DC Resistance at 20°C (Ω/100M) < 0.919
Min.Insulation DC Resistance at 20°C (MΩ*M) >200
Rated Temperature (°C) -30°C – +75°C
Rated Voltage (V) 300
Capacitance (pF/M) 53.2 ± 5
Impedance(Ω) 200 MHz 75± 5
Attenuation at 20°C (-dB/100m)(± 15%) Value:
1.00 MHz 0.787
71.50 MHz 5.545
100.00 MHz 6.398
180.00 MHz 8.432
270.00 MHz 10.401
750.00 MHz 18.046
1000.00 MHz 21.064
1500.00 MHz 26.215
2250.00 MHz 32.843
3000.00 MHz 38.650
Return Loss (-dB/100m) (min.)
5-1600 MHz > 19dB
1600-4500 MHz > 18dB
Physical Characteristics
Sheath Tensile Strength 10.00 N/mm2
Sheath Elongation at Break 100%
Braid screening Coverage 95.00%
Conductor Elongation at Break >25.0%
Minimum Bending Radius 104.25mm
Dimensional Features Material Breakdown
Inner Conductor BC1.02(+0.018/-0.018)mm Solid bare Copper
Insulation 4.60 (+/-0.20)mm Foam PE Insulation
Shield Double Al-foil shield Double Al-foil shield
Braid TC0.12(+0.008/-0.008mm) x192 Tinned copper Braid Shield
Sheath 6.95(+0.10/-0.18)mm Black LSZH SheathIs this any good?
Ben
Ben Edwards – Freelance Picture Editor
https://www.funkytwig.comi5 3550 3.3Ghz, Windows 7 / Mac Lion, Nvida 550 Ti, 16GB Mem
