SDI Audio and Analog out of sycn
I just got a new SDI monitor and when I play the audio on the monitor via SDI it is 2 to 3 frames out of with the the analog audio out via XLR’s from a Kona LHe going into a Mackie 1402. I Trust the embedded SDI audio but the question is why and how do I get them right. If I slip the playback control in FCP from 4 to 7 the audio matches but the computer monitor is way off. I also post on the Kona.
