Activity Forums AJA Video Systems SDI 1 input on Kona 3 not working
  • Tyler Dixon
    May 31, 2008 at 4:14 pm
    Hello David,
    I couldn’t find the snake, but re plugging all the small BNCs on the card fixed it.
    Gary
  • Gary Alan
    June 2, 2008 at 3:12 pm
    it appears to be an intermittent connection on the smallBNC’s that connect to the card in the Mac or the connection on the card.
  • Jeremy Garchow
    June 2, 2008 at 3:22 pm
    [Gary Alan] “it appears to be an intermittent connection on the smallBNC’s that connect to the card in the Mac or the connection on the card.”
    You should try and track down the cable snake and eliminate your problems from there.
    Jeremy
  • Gary Alan
    June 2, 2008 at 5:04 pm
    I just started working here a few weeks ago. No one here knows where the snake cable is or if we have one. Just the K3 box. Room is busy now. Later I plan on switching the small bncs from 1 to 2. It was only SDI 1 input that was flaky. If problem moves to SDI 2 input with the #1 BNC, then the plug/cable is the culprit. If it Stays on the card #1 input, then the card connector is flaky. Someone probably yanked the cable too many times before I got here.
Page 2 of 2
