SD?HD monitoring from edit bay
Hi, we are using a Grass Valley Edius NX system for post work and currently monitor on a HD LCD TV. A majority of our work is still SD with increasing mixing of SD/HD formats or an occasional Full HD job so we need to be able to monitor both types of projects from one system. Our main concern is that the SD stuff presented on the HD LCD screen looks like crap and we think it mostly due to the poor quality conversion from the TV. The content is sent to the monitor using component out from the Edius NX breakout panel.
We have seen several other small post suites where the SD content is up-converted before getting to the monitor using a processor like something from aja and thought a combination of your mini-convertors might do this job (better).
Can we combine (connect) the analog to sdi mini-converter with the sdi to hdmi mini-converter (and then to the HD panel) to improve our presentation of the SD content? Also, the editing system can switch signals for a particular project on the fly – would that be a problem with the mini-converters? Finally, we are planning on replacing the existing HD TV with a newer one – is there any tech details we need to know beforehand about connecting the converters to a LCD HD TV (anything about the tv that should be considered), assuming the mini convertors mentioned will help?
