Activity › Forums › Sony Cameras › SD video out of BNC?
Posted by Bob Mark on October 19, 2010 at 12:31 pmIs it possible to get SD video out of the BNC connector on an EX1? If so, what do the menu settings need to be for this? Thanks.
Bob Mark replied 15 years, 10 months ago 4 Members · 13 Replies -
Ian Cook
October 19, 2010 at 1:26 pmHi Bob,
Menu–>Video Set–>Y Pb Pr/SDI Out. Set this to ‘SD’ to get SD-SDI and SD component output. Also make sure that Menu–>Others–>i.LINK I/O is set to ‘Disable’ as enabling the firewire output disables the SDI output.
Best,
Ian
Bob Mark
October 19, 2010 at 3:28 pmI must have something else set wrong. All I get is bouncing snow. B&W noise. Any suggestions?
Bob
Ian Cook
October 19, 2010 at 3:33 pmWhat format is the camera set to? If it’s set for 23.98, does your monitor accept 23.98? In playback of 23.98 the camera output is 60i but depending on the setting of Menu–>Video Set–24p the ‘Live’ camera head output can be either 24p or 60i. Can you verify this?
Klaas Van urk
October 19, 2010 at 4:39 pmThe BNC connector gives SD-SDI or HD-SDI signal. If you need an analoge composite signal you should use the analoge out connector hidden behind the grip. There is a cable supplied which has in one side cinch connectors. The cable will hinder your hand on the grip.
An other option is to use a small serial digital encoder like the AJA D4E. It takes SD-SDI input and gives composite or S-video out. I use one when I need a more ‘robust’ output. -
Ian Cook
October 19, 2010 at 4:42 pmTry resetting the camera from Others–>All reset. Also you might want to try with a different monitor just to be sure. The SD output is 480/60i so you should not need a particularly high end display to get a signal.
Ian Cook
October 19, 2010 at 4:52 pmYes but you can save them and recall them. Others–>Camera Data–>Store/recall. You’ll need a media card in the camera to store the file.
Bob Mark
October 19, 2010 at 5:10 pmOK. Tried it. ilink is disabled. Set to output SD and still just snow.
Bob
