Activity › Forums › Sony Cameras › SD video out of BNC?
  • Craig Seeman
    October 19, 2010 at 5:17 pm
    Bob, maybe I missed something in this thread but what are you trying to send the signal to?
    The standard def output is still Serial Digital (AFAIK) so if you’re trying to send to an analog composite BNC input device, you’d probably get snow.
    In other words it’s SD from an SDI rather than composite even though the connectors look the same.
  • Ian Cook
    October 19, 2010 at 5:21 pm
    Are you sure your monitor can accept an SDI signal? Are you feeding the SDI into an analog input? If the port can take SDI it will almost definitely say ‘SDI.’ If it says ‘Video in’ it is probably an analog input. If it’s not the monitor it may be an issue with the output of the camera.
  • Bob Mark
    October 19, 2010 at 5:50 pm
    Ok. I understand now. The monitor does not have the proper digital input. Thanks guys, I appreciate the time and effort. I will use the CAV out.
    Bob
    Bob
Page 2 of 2
