Activity › Forums › Apple Final Cut Pro Legacy › SD to HD in FCP
SD to HD in FCP
Posted by Joseph Bradley on September 24, 2005 at 3:25 amCan I capture SD but edit and export in HD?
Using G5 2gh- Kona 2. capturing from a DVX100Walter Biscardi replied 21 years ago 3 Members · 2 Replies -
Shane Ross
September 24, 2005 at 5:54 amThe Kona 2 has the ability to upconvert SD footage of HD.
If it is DV though, it won’t look that good. Basically zooming into the footage nearly 200%.
Walter Biscardi
September 24, 2005 at 2:19 pmYou’ll probably get a lot of “jaggies” around the edges of object and you’ll notice the interlacing lines are very pronounced when you upconvert DV footage. The best way to do an upconvert from DV is to use something like a Terranex converter which you can find at high end post houses or a transfer house. With the right coloring and transfer, your DV footage can look like true HD. http://www.cinefilmlab.com is a fantastic house here in Atlanta that can perform the service.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
