SD to Blu-ray
Ok, I have some dv 720×480 that I would like to put on Blu-ray, as opposed to DVD, because I want to be able to put as much video as I can per disc. I am using Vegas Pro 9 and DVD Architect 5.
1. I still need to seperate each video stream to different videos. What resolution should I use to render to from Vegas, keeping in mind that they will be put into DVDA and authored to Blu-Ray?
2. What setting do I need to use for DVDA? The default is 1080i.
I have done some testing, and strangely enough, the best results that I have gotten have been to render from Vegas to 720p, and then use the 1080i template in DVDA. This looked better than rendering to both 1080i and 720×480 in Vegas and then using 1080i in DVDA.
Please help. How would you go about this? Thanks!
