SD pan-crop from HDV
Making some tests with SD (wide) pan-crop from HDV (1280 x 720) source:
– crop window with lock aspect ratio and making height 480 (853.3 results in width).
– position my window selection or keyframe panning.
– render to NTSC-wide AVIis this final rendered AVI something like the obtained from a DV-widescreen (SD) captured from tape ??? is this method correct ???… I guess this also applies to XDCAM-EX files (and with better panning options having a 1920 x 1080 file size….)
am I right with this ??? any comment would be greatly apreciated…
kind regards
