Activity Forums Apple Final Cut Pro Legacy SD PAL project with progressive elements problem
  • SD PAL project with progressive elements problem
    Posted by Kazumi Hatori on May 14, 2010 at 10:14 am
    I’m working on some SD PAL projects, with footage shot from DV camera and being SD PAL (interlaced).
    So I edit in Final Cut. On the same time, I made some OP, lowerthird from after effects in rendering out as animation/PNG codec (with alpha).
    Problem comes when I put the graphic elements(progressive) in FCP,
    after exporting out as SD PAL clip, the footages look fine but the graphics are interlaced.
    May I ask what’s the correct workflow on that?
    Kazumi Hatori replied 16 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    May 15, 2010 at 12:00 am
    SD PAL is interlaced so that is normal for your sequence settings. Is there a problem with the graphics? I drop tiffs & png graphics into SD timelines without any problem. If there is movement or animation then I ask the AE people to export with fields on and there is no problem with credit rolls etc.
  • Kazumi Hatori
    May 15, 2010 at 10:41 am
    It’s just normal still & motion graphic.
    Never try a sequence, I would give a try, though I think a single quicktime file can be more well managed.
