Activity Forums Sony Cameras SD out on 330 camera?
  • SD out on 330 camera?
    Posted by Bob on June 7, 2007 at 3:40 pm
    Has anyone else had trouble wirelessly transmitting video out of a XDCAM? Has anyone had success? If so what transmitter system are you using?
    Accountclosedduetopolicyviolations replied 19 years ago 3 Members · 2 Replies
  • Tony
    June 11, 2007 at 5:11 pm
    Bob,
    The HD “Y” analog will never work with a device which is expecting NTSC.
    The “Y” output is for HD analog only.
    You should look at the SD signal on a wavemonitor to confirm if it is one volt peak to peak and/or if you are having any issues with the encoder on the camera.
    Tony Salgado
  • Accountclosedduetopolicyviolations
    June 11, 2007 at 8:07 pm
    F-330 downconverts from HD to component analog out.It is all in menu.(PAL)
