Activity Forums Panasonic Cameras SD monitoring for HDX900?
  • SD monitoring for HDX900?
    Posted by Jason Starr on April 18, 2007 at 3:51 pm
    I need to monitor our HDX900 on a standard definition monitor which only has analog inputs (composite, s-video and component). Is there a menu setting in the HDX900 that will allow me to switch the monitor output to SD composite? Thanks for your help!
    Patrick Forestell replied 17 years, 4 months ago 3 Members · 3 Replies
  • Ray Palmer
    April 18, 2007 at 5:25 pm
    The HDX900 has two video ouputs, one switchable and one non-switchable .
    The rear video out can be switched as HD-SDI, SD-SDI or composite, sometimes refered to as VBS, video blanking sync.
    The rear side video out is ALWAYS HD-SDI only.
    BTW, the switch is on the left side of the camera and is a hard switch not a menu.
  • Jason Starr
    April 18, 2007 at 8:50 pm
    Got it! Thanks for your help Ray.
  • Patrick Forestell
    April 19, 2009 at 9:31 pm
    I hope you don’t mind me asking but I have an SPX800 and one of the output options is a “Y” signal which of course is black and white luminance with no color. Question, does the SD camera SPX800 have an adequate color signal output that would marry with the “Y” signal to yield S-Video out ?
    PS: I have SDI SD out, VBS (Comp) and Y, but where is S-Video out ?
