Activity Forums DVD Authoring SD DVD vs. Blu Ray for Movie Theater Projection
  • SD DVD vs. Blu Ray for Movie Theater Projection
    Posted by Melissa Townsend on January 9, 2011 at 7:04 pm
    My 10 minute short shot on the canon 5D mark II is showing at a film fest.
    It will be played on a DVD player, but projected onto a movie theater-sized screen.
    I have the option of submitting an SD DVD or Blu Ray. I can easily make an SD DVD, but is it worth it to get someone to make me a Blu Ray disc?
    Michael Slowe replied 15 years, 8 months ago 3 Members · 2 Replies
  • Michael Sacci
    January 9, 2011 at 7:41 pm
    By all means make a BluRay disc. Making a sime play only BluRay should be less than a $100. Bluray burners are getting pretty cheap and making screeners like this is pretty easy. The expensive comes in when you are trying to make something that can be replicated.
  • Michael Slowe
    January 9, 2011 at 10:08 pm
    I have had both SD DVD’s and Blu-Ray projected in a cinema and provided they have an upscaling Blu-Ray player your DVD should look pretty good. Obviously it would be preferable to project a BD but not critical. If you’re shooting and editing in HD why not do your own BD’s? I just got the Lacie stand alone burner which goes into the MacPro through a USB 2 connection and it works fine. I use Toast 10 (with the BD plug in) to encode and burn and the results are great. Post houses charge quite a lot for stuff quite easily done by us in our edit suite.
    Michael Slowe
